| | | Forums66 Topics128,121 Posts1,056,328 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 231 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 231 | Does anyone know if an 64 impala underdash a/c unit would work in my 63 C-10? is it the same as would be used as a dealer install? Thanks, Pete 1963 Chevy C-10 Fleetside 1970 C-30 Dump Truck 2025 Silverado High Country 2500 Diesel 2012 Indian Chief Vintage serial #002 motorcycle 1946 Indian Chief, 1947 Indian Chief w/sidecar,2014 Indian Chieftain, 2015 Indian Scout | | | | | Joined: Nov 2006 Posts: 231 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 231 | 1963 Chevy C-10 Fleetside 1970 C-30 Dump Truck 2025 Silverado High Country 2500 Diesel 2012 Indian Chief Vintage serial #002 motorcycle 1946 Indian Chief, 1947 Indian Chief w/sidecar,2014 Indian Chieftain, 2015 Indian Scout | | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | I'm curious as to what you found out about the fit of you A/C? And what does it mean when someone say's "bump"? Tramp | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | If it is used I would be afraid of it. It only takes a little piece of trash to blow a compressor. I'm not an air expert but I play one on TV.
~Jim
| | | | | Joined: Jun 2009 Posts: 54 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 54 | Cool Pack air conditioner unit? | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | If it is used I would be afraid of it. It only takes a little piece of trash to blow a compressor. I'm not an air expert but I play one on TV. So long as it is cleaned properly it should be fine to use. | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | Tramp,
The term "bump" means he just added a reply to "bump" this thread back to the top of the list. | | | | | Joined: Feb 2009 Posts: 23 New Guy | | New Guy Joined: Feb 2009 Posts: 23 | You might want to consider the Mark IV underdash a/c unit by Vintage Air. Externally it's an exact metal replica of the unit built in the '60's and '70's with modern interals for reliability. http://www.vintageair.com/08/catalog08/08%20VA%20cat%20pg%2023%20f.pdfHere's a response from another site posted by a Vintage Air rep. "The Mark IV is a great new product just released from Vintage Air and is selling great....it also works as good as it looks. The Mark IV evaporator list for $299.00 and is a cool only system so normally you will retain your OEM heater. The evaporator is just one component of an A/C system, you will also need an compressor, bracket, condenser, hose kit, drier and safety switch which normally runs in the $880.00 - $900.00 range but could be a little less or more expensive, depending on what parts needed to fit your ride. The evaproator itself is 15.5"W x 5.75"H x 13.5"D. All of the guys in VA Sales/Tech Depts are gear heads and lurk around the HAMB daily (don't tell Jack). Most of us have attended/participated in every Lone Star Roundup and think it's the best show in the country. We think the HAMB Alliance is a great idea but being a manufacture with a large dealer network, we do not want to be in pricing competition with them and sell @ retail only. I know several HAMBers who are VA dealers so I would recommend seeking them out and keep it in the HAMB family. If anyone has a question about the Mark IV or any of the VA systems, don't hesitate to contact myself or any of the guys in the Sales Dept....we are here to help out any way we can!!" Thanks again, Mark Hungerford Vintage Air Tech. Dept. 1.800.862.6658 ext.111 | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Any one know how many passes this evaporator has?
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 |
