| | | Forums66 Topics128,050 Posts1,055,760 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#61472 06/08/2006 4:29 AM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Was wondering if any of you 235/T5 folks were running a cross member/S10 mount under your conversions? I have the single front engine mount and side mounts on the bell housing and had planned on fabricating my own cross member but got to thinking that this would make it a 4 mount system that might set up some extra stresses between the T5 and the bell housing. I don't really feel comfortable with the unsupported transmission hanging way out in back so if you've got some suggestions, they would be appreciated. | | |
#61473 06/08/2006 5:07 AM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | I used a universal type crossmember. I believe it was a 4 inch drop. They have different size drops. I got a 2" first and it didn't fit, if I remember correctly. I got it from a local hot rod shop but you can find em all over. Good luck. | | |
#61474 06/08/2006 3:11 PM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I've seen several of the cross members for transmission mounts at the swap meets. Most of them are for automatics, I believe, but could work. My original cross member goes under the T-5 transmission with about 7/8" left between the transmission rear mount and the cross member. The crossmember lines up directly under the T-5 mount. I can use it if I can come up with some kind of mount. Most of the production mounts I've seen are about 2" thick, so I'm going to have to invent my own, I guess. I really don't see why you would have any problems mounting the tail of the T-5 to a cross member. My stock transmission was tied to the crossmember and I, too, have the front motor mount with the bell housing mounts. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#61475 06/08/2006 5:04 PM | Joined: Dec 2003 Posts: 299 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2003 Posts: 299 | 55-57 Chevy used that system, I raced around in those for years and never had any problem what so ever. You could actually add a cross member in there as well if you want some real support making it a 5 point system. for the front I used a 73-77 Chevelle trany cross member facing bacwards.Then I drilled the holes for the mounts into that and cut it to the correct width, finally welding plates to the sides of it so I could bolt it to the inside of the frame. It had the exact angles on it for the front mounts. Lothar | | |
#61476 06/08/2006 11:52 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | mine is a simple 2''x 3'' box tube run dead straight across the frame. uses the stock T5 rear tranny support rubber. two grade 8, 1/2'' bolts attach to the bottom side of the frame which has been re-inforced along that stretch of frame. this angle allows for the 2-3 degrees tilt needed off my 292 motor. The 292 has two offset biscuit style rubber mounts. I just have three points of support. the T5 weighs in @ 75-80 lbs., but w/ the two forward and third support @ the rear of the tranny I feel that's good.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#61477 06/09/2006 2:39 AM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Thanks guys! I was just a little concerned with using a 4 point mount system. The 6's torque moves things around and I didn't want to set up anything that was causing undue stress on the mounting flanges. A friend who builds and races modifieds mentioned that they used solid motor mounts and just left the aluminum Muncie (I think) hang out unsupported. He said the only time they had a problem was when an engine or diff let go. Think I'll go ahead and fab a crossmember just to be safe. (conventional)
Thanks again. | | |
#61478 06/09/2006 3:48 AM | Joined: Oct 2002 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 77 | I have been running a T-5 without a rear crossmember for almost 2 years now with no problems, the support from bell housing mounts are all that is needed. | | |
#61479 06/09/2006 7:01 PM | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | I didn't plan on putting one in either. While longer, the T5 is much lighter than a 420, which, on my '54 never had a rear support. | | |
#61480 06/09/2006 7:36 PM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Some guys are running an adaptor plate between the bellhousing and trans, in this case the crossmember is a must. But, the factory used a mount at the rear so I'd do the same. | | |
#61481 06/10/2006 5:22 PM | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | I modified the original crossmember in my '53. I sent you some pictures. Real easy and looks like it could be factory. Good Luck. Colin | | |
#61482 06/10/2006 11:10 PM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Thanks again folks, you've given me some great ideas and a bunch of options. Colin, the pictures of your crossmember were absolutely outstanding. You should have a website set up to share your work. Speaking of websites, I have recently added a site to chronical my first venture into the GM product line. If you want to take a glance at it you can find it at: http://community.webshots.com/user/Fla54Chevy3100 Once again, thanks to all of you who helped make this project a whole lot more fun!!! Dave | | |
#61483 06/10/2006 11:50 PM | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Hey Colin, could you pop those pictures to me too? I like the looks factory look.
40 Chevy 1/2 ton
#61484 06/11/2006 8:16 PM | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | Sure thing Dennis. They are on their way. Dave, I had a webshots running for a while but haven't updated it in months because I have dial up and it takes forever. We'll see what I can do.
Colin | | | | | Joined: Feb 2013 Posts: 12 New Guy | | New Guy Joined: Feb 2013 Posts: 12 | Just wondering if you could send me some of those T5 crossmember pics?? Cuz I'm doing the same. Thanks! | | |
