1 members (Youngin' Tut 59),
123
Mod | | | Forums66 Topics128,201 Posts1,057,276 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2003 Posts: 1,381 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,381 | A local junkyard has whats left of a panel truck (47 to 53) that still has the front sway bar on it,I looked it over and the bushings and links that attach the bar to the axle are shot so are these parts available anywhere or would it be best to buy a new one. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | you can get a complete bushing set from JimCarter. I think the entire set runs about $50. I tried making some of the urethane bushing from the local parts house work but they just don't cut the mustard. | | | | | Joined: Dec 2009 Posts: 24 New Guy | | New Guy Joined: Dec 2009 Posts: 24 | Hi Jeff, There is a classic truck parts supplier that I get a lot of my parts from called Jim Carter. They have a lot different parts you can buy, new and used. Their prices are usually pretty good too. Maybe they can help you find what you're looking for. Here's a link to Jim Carter Truck Parts Jim Carter
If it ain't a Chevy, It ain't nothin'.
| | | | | Joined: Feb 2003 Posts: 1,381 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,381 | I looked a little on Chevs of the 40s website and did not find much for the original swaybar. | | | | | Joined: Feb 2003 Posts: 1,381 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,381 | I think I will get a new one as the links that attach the bar to the axle are broken and it does not look like replacements are reproduced. | | |
