9 members (warlock, mick53, 55shaker, fonz8261, Ponchogl, RoadsScholar, Gdads51, Otto Skorzeny, 32Fordpuchoptop), 105 guests, and 2 robots.
Topics128,048
Posts1,055,626
#614569 01/29/2010 1:54 AM
I have a 350 olds in my truck and had just installed a new starter . The problem is when I turned the ignition on and hit the starter button it would engage and turn slowly . I let off the starter button and it was still slowly turning over . Then I turned off the ignition and it still turned over slowly . I had to unhook the battery to stop it cranking . I was wondering, if the starter needs shimming ? If it was too tight would it keep the starter gear engaged and keep current flowing ?
If everything's coming your way , your in the wrong lane...
1958 GMC Shorty
It sounds like it needs to be shimed a repair manual for that engine will spell out the best way to do it.
Pete
Pete52 #614666 01/29/2010 5:45 AM
I bench tested the new starter . I grounded the body and flashed the positive to the "S" terminal & the heavier main terminal . The solenoid works but the starter doesn't crank . Any ideas ? it also has a "R" terminal but my truck only has a positive to the starter and one wire from solenoid to starter button .
1958 GMC Shorty
Problem solved , I had to hook the heavy + terminal , then flash the S . Now to deal with the shimming . Thanks for your reply Pete52 .
1958 GMC Shorty
