| | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 100 | 1965 c-20, 3 speed. what type of engines can i put in it.
It's better to have it and not need it, then it is to need it and not have it. "Woodrow F. Call"
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I'm not up to snuff on your models but I would think you could easily put any small block or 6 cyl in that year range but I am not sure about what tranny hook up you have or plan to run. | | | | | Joined: Jul 2006 Posts: 240 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 240 | Anything from a 283 to a 502 or probally larger will bolt up to that bellhousing, plus 194-230-250-292 6 cyl. That would be the stock to that truck standard shift bellhousing.
You Learn more Listening than Talking
| | | | | Joined: Mar 2009 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 100 | update: i am looking at a chevy crate inline6, 3.8 L, 230 CID - i will be ruuning the prginal transmission/bellhousing.
| | | | | Joined: Dec 2009 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 43 | without your just wanting crate motors i have 2 original 230s. i live in north alabama. complete engines. make you a good deal on either one. need space cleaned out. | | |
