7 members (Otto Skorzeny, UtahYork, Ponchogl, Lonnie, Bicounty, BC59, JW51), 160 guests, and 4 robots.
Topics128,089
Posts1,056,129
Members48,435
Apprentice
Apprentice
Hi All-
I need to pull out the original front drive shaft bushing from my '53 half-ton stock torque tube, and apparently there is but one tool on the planet that can do it without having to take the rear-end completely apart. (link to picture below).
Does anybody have one of these sitting around that would consider selling, trading, or renting for this one-time job?
Thanks, -Warren
Front Bushing Puller Tool
Apprentice
Apprentice
BTW- I should mention- if you don't have the bushing puller, but know of another way to get this front bushing out without pulling the rear end apart, PLEASE let me know! Thanks, -Warren
The Filling Station rents and sells this tool
My Blog
I have taken several torque tube front bushings out.
Remove the dowel pin that locates and restrains the bushing.
Carefully drive the bushing (thru the dowel hole) out with a small drift , just enough to get the big grips on it. Pull/rotate , till it is out. smile
Apprentice
Apprentice
Dusty-
Thanks for the tip. Unfortunately my '53 3100 does not have a dowel pin holding in the front bushing- (I've looked and looked). It's pressed in, no hole.
I think I can make a tool that will work for this, and if not I'll probably rent it from the Filling Station. Thanks Pre '68 Dave!
-W
ODSS Lawman
ODSS Lawman
In order to get this bushing out, you still need to remove the pinion so that the splines are out of the way. Check out my webshots page to see the tool I used to do it..
Here is a link
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
Sweet, this puller fits around the splines so it can be done in the car/truck without disassemble. You had an Okie in yours already, this puller will not work for pulling those.
My Blog
