2 members (ShopRag, GradyB),
116
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,035 Posts1,055,564 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 134 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 134 | I have a bolt hole on the top of my 216 engine that I don't have a clue what should be in it. I found it as I was adding antifreeze. Any ideas? http://s835.photobucket.com/albums/zz276/hdstickel/1953%20Chevy%20Engine/thanks Charlie
1953 5 Window 1994 Harley, Heritage Softail Classic 2006 Chevy Colarado I didn't say it was your fault, I said I was blaming you.
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Temp gauge hole for the sending unit
Pete | | | | | Joined: Mar 2009 Posts: 134 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 134 | If that is true then what is the hole on the side of engine that I have the temp sending unit in? Could there be more than one?
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Hole on side may be oil pressure. Can you post another pic?
Drew
| | | | | Joined: Mar 2009 Posts: 134 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 134 | Well when I first started filling up the engine with antifreeze, the hole on the side started leaking antifreeze, I put the sending unit in it. I anin't a smart man but I don't think it the oil pressure. I will take more pics tonight and post them.
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | The hole on the side, if it's toward the rear of the block, is for a plug or a petcock type drain valve. | | | | | Joined: Mar 2009 Posts: 134 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 134 | Now that make sense, do you know what size petcock?
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | I don't, but I am sure the smarter guys here will chime in pretty soon. | | | | | Joined: Mar 2009 Posts: 134 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 134 |
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Well when I first started filling up the engine with antifreeze, the hole on the side started leaking antifreeze, I put the sending unit in it. I anin't a smart man but I don't think it the oil pressure. I will take more pics tonight and post them. LOL. Definitely not oil. It would be a 1/8" pipe plug or drain petcock. You can buy at any auto supply.
Drew
| | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | I think that one is actually a 1/4" pipe thread. Ditto on using the petcock- - - -it's a lot easier to drain the block or do a flush by just opening the wing nut valve. BTW, that's not a good place to put the temp gauge. There's an adapter that needs to go to into the hole inthe head, and the temp gauge bulb screws into the adapter. The block thread will leak if you try to put the gauge tube in without the adapter, and the hole in the block isn't big enouth to accept it. Jerry
| | | | | Joined: Mar 2009 Posts: 134 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 134 | Thanks Jerry,
Ive seen the adapter in many of my catalogs one is on order. What can I put in the hole as a temp fix until I get the cab back on the frame.
Charlie
| | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | I think a plain old 1/2" pipe plug will keep it from leaking. Just put a little pipe dope or liquid Permatex on the threads as you install it. Some engines use a 3/8" pipe thread instead, so you've got a 50-50 chance of guessing right the first time. Jerry
