| | | Forums66 Topics128,049 Posts1,055,552 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#61334 06/05/2006 9:15 AM | Joined: Jan 2006 Posts: 27 New Guy | | New Guy Joined: Jan 2006 Posts: 27 | So far, all of my questions on this forum have been hypothetical or pertaining to issues not mission critical if you will, so tonight I had my first true breakdown. The bushing that supports the driveshaft just past the joint wore out, so now the driveshaft is scraping against the iron support. I was able to jerry-rig it using a ton of rope and basically harness the driveshaft so that it wouldnt just flex and saw itself in half long enough to get it to a place to park, but as of now I am stuck. Any suggestions, or stories from the past? Should be an interesting one to fix, but I don't suppose there's a better way to learn these things. . . | | |
#61335 06/05/2006 8:36 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | You must be asking about the carrier bearing used on the 2 pc. driveline. This is a rubber mounted bearing that is used to support the midship stub shaft (splined). Drop the rear shaft out by removing the u-bolts at the differential and slipping it forward to clear the yoke on the differential. Then remove the front shaft the same way and take the shaft to Drivetrain Industries or Driveshaft Specialists in Denver and have them inspect and replace the carrier bearing and any other parts needed. Replace the shafts by installing the front one and then the rear but be very carefull of getting it back in phase when reinstalling the slip yoke onto the slip stub. Ask the company you choose what is meant by that and they will show you. Without a press and proper inspection of the parts you are likely in for a tough go and may be in over your head depending on your skills. It is much easier to let a good shop do this repair and also a good time to replace the U joints if needed. | | |
