6 members (Jon G, baldeagle, Oswald, fonz8261, Hotrod Lincoln, 1 invisible), 55 guests, and 3 robots.
Topics128,015
Posts1,055,334
Members48,419
#613307 01/25/2010 3:23 PM
I have a bolt hole on the top of my 216 engine that I don't have a clue what should be in it. I found it as I was adding antifreeze. Any ideas?
http://s835.photobucket.com/albums/zz276/hdstickel/1953%20Chevy%20Engine/
thanks
Charlie
1953 5 Window
1994 Harley, Heritage Softail Classic
2006 Chevy Colarado
I didn't say it was your fault, I said I was blaming you.
Temp gauge hole for the sending unit
Pete
If that is true then what is the hole on the side of engine that I have the temp sending unit in? Could there be more than one?
1953 5 Window
2006 Chevy Colarado
Hole on side may be oil pressure. Can you post another pic?
Drew
Well when I first started filling up the engine with antifreeze, the hole on the side started leaking antifreeze, I put the sending unit in it. I anin't a smart man but I don't think it the oil pressure. I will take more pics tonight and post them.
1953 5 Window
2006 Chevy Colarado
The hole on the side, if it's toward the rear of the block, is for a plug or a petcock type drain valve.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Now that make sense, do you know what size petcock?
1953 5 Window
2006 Chevy Colarado
I don't, but I am sure the smarter guys here will chime in pretty soon.
1953 Chevrolet 3600
Thanks Mater
1953 5 Window
2006 Chevy Colarado
LOL. Definitely not oil. It would be a 1/8" pipe plug or drain petcock. You can buy at any auto supply.
Drew
H Online: Content
I think that one is actually a 1/4" pipe thread. Ditto on using the petcock- - - -it's a lot easier to drain the block or do a flush by just opening the wing nut valve. BTW, that's not a good place to put the temp gauge. There's an adapter that needs to go to into the hole inthe head, and the temp gauge bulb screws into the adapter. The block thread will leak if you try to put the gauge tube in without the adapter, and the hole in the block isn't big enouth to accept it.
Thanks Jerry,
Ive seen the adapter in many of my catalogs one is on order. What can I put in the hole as a temp fix until I get the cab back on the frame.
Charlie
1953 5 Window
2006 Chevy Colarado
H Online: Content
I think a plain old 1/2" pipe plug will keep it from leaking. Just put a little pipe dope or liquid Permatex on the threads as you install it. Some engines use a 3/8" pipe thread instead, so you've got a 50-50 chance of guessing right the first time.
