12 members (Paul_WNC, Wally / Montana, Woodcmiami, Joe H, baldeagle, tonyt, DannyW, Bill Hanlon, walter74, gswbbc, lumbersawyer, 1 invisible),
94
Mod | | | Forums66 Topics128,040 Posts1,055,475 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 27 Apprentice | | Apprentice Joined: Jan 2010 Posts: 27 | I just bought a 48 chev,and after reading many posts here have come to think that the doors on the truck may have been changed. The door handles are push button type and my understanding is they should be lever type. Also doors have window vent in them. Any thoughts would be a great help. thanks
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Sounds like you have '52-'55 1st doors. Strangely enough, it's usually the other way around. Most guys swap the earlier doors onto the later trucks to pass them off as a "'48" to get into hot rod shows, most of which have a 1948 cutoff year.
Bill Burmeister | | | | | Joined: Jan 2010 Posts: 27 Apprentice | | Apprentice Joined: Jan 2010 Posts: 27 | | | | | | Joined: Jul 2007 Posts: 293 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 293 | You are correct. Your doors are not original. A '48 would have a full window (without a vent) and it would have a turn down door handle (not a push button). Vent windows and push buttons appeared in the early 50's. | | | | | Joined: Jan 2010 Posts: 27 Apprentice | | Apprentice Joined: Jan 2010 Posts: 27 | Would you agree that the would be 52-55. I need to replace glass in one of them. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | The 51's were the first year for wing vents but still had the pull down handles.... 1952 is the first year for push buttons...So, 1952 was the first year with BOTH the vent window and PUSH BUTTON handles and on through the 55st series.
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Alvin,are you sure 1952 had pull down handles ? I thought 1951 was the first year for wing vent window and the last year for pull down door handle. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | TIM...you have a sharp eye. Me, of all people should know!! It was a typo on my part and I just went back and EDITED it so no one gets lead astray. Thanks TIM and sorry for anyone who may have already read it and is wondering!!
1952....first year for Both wing vents AND PUSH BUTTON handles. Hope this clears it up. I'm tired and better go to bed before I make another mistake!! | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I wish the 51 had the push-button handles. The only problem as I see it is when you are at the gas station people will be always suggesting it's a 52 up truck and you will have to explain where those doors came from.
~Jim
| | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | I just bought a 48 chev,and after reading many posts here have come to think that the doors on the truck may have been changed. The door handles are push button type and my understanding is they should be lever type. Also doors have window vent in them. Any thoughts would be a great help. thanks How do you know that it is a 1948? It could be a 1952 and have the right doors. We can't assume it is a 1948, even if the title says so. Got pic's?  | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | I dont remember all the cab differences, however I do know the following:
If it has a single rear cab mount, single lower radiator mount, fuel tank underneath the bed - then it would be a 48. If it has shackle cab mounts, twin lower radiator mounts, and the fuel tank is in the cab then it would be a 52
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I thought the twin lower rad mounts began in 53. Is that not right?
~Jim
| | | | | Joined: Aug 2002 Posts: 154 'Bolter | | 'Bolter Joined: Aug 2002 Posts: 154 | | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | It must be a 1/2 ton versus 3/4 ton. My 51 3600 has the single mount.
~Jim
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Both of my 1951 3100 chevys have the twin mounts . Post some pictures of your 1948 truck. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | If you are only concerned with the glass in the doors, then the answer is: the glass is the same from 1951 - 1955 first series doors, including the panel and the suburban.
A simple check will confirm a few things.:
Vent in drivers side cowl - 1947/50
1951 cabs are pretty close to the same and hard to identify without the doors, body tag or latch.
Without the doors, the latch helps identify the year. 1947/51 used the same latch and the 1952/55 used another. | | | | | Joined: Jan 2010 Posts: 27 Apprentice | | Apprentice Joined: Jan 2010 Posts: 27 | Hopefully I can get some pics up soon. The truck is titled as a 1948. The gas tank is under box and the cab is attached to frame at three points. From what Ive read that should mean it is a 48.The truck has a radio and a clock that is mounted in the glovebox door. The truck is in suprisingly good shape. As I mentioned before I have owned it for a couple weeks now. I am trying to decide if I should keep it original or put it on a S-10 frame. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I thought the twin lower rad mounts began in 53. Is that not right? My 50 has the twin mount. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | It must be a 3/4 ton deal. Denny Graham's 1951 3600, as does my 3600, has one mount.
~Jim
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Most likely (as stated above), the number of attaching bolts under the radiator support was different for different sized trucks in different years (making it hard to make general statements).
The 1947-55 Factory Assembly Manual (mostly showing 54/55 diagrams) shows the 3100 and 3600 models' radiator support to frame cross member attachment as having two bolts, and the 3800 and larger models had one bolt.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | This is a really interesting discussion. One thing that wasn't mentioned was I believe the cabs with the external tank had a second inner panel of metal across the back. I blieve it was said that the tanks from a 52 didn't fit back there. I have an old factory photo of a cab being built and you can see the extra panel.
Also in one of my shop manuals from 1947/48 I have the instructions on converting the rad mount to two bolts and also adding ther cross bracing. This was a field modification to prevent cracking of the rad and some other structures. It also details crack repair procedures for some of the underside of the cab.
My 1951 Canadian 1 Ton had the single bolt rad mount. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | All I know for sure is that the 1951 3/4 ton had only one rad mount. I sure wish we could find assembly manuals for all AD years, and for that matter all years.
~Jim
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yes there was a period when the half-ton had two mounting bolts for the core support and the 3/4-ton had only one. This oddity was much like the one about the core support cross braces where the 1/2-ton had them first and the 3/4-ton didn't. Also the three point vs. four point mounting of the cab entered into these changes because of twisting of the frame cab and front clip. I believe there were service bulletins out for some of these changes also if someone cares to check them out. We had a rather lengthy discussion about this a couple of years ago and Woody may remember them, I've never had any luck with the search engine here. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yeah Tim, those are the ones, that should answer a bunch of the quesitons. DG
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | He has the under bed tank - that makes it a 47 or 48. After doing a frame swap myself, I would keep the frame original and drive it. If your looking for a good ride, Mono springs. If your looking at upgrading to IFS for the sake of upgrading - check out this https://www.stovebolt.com/ubbthread...;Main=80741&Number=571697#Post571697
