8 members (rfs56trk, Frank50, BarryP, Gazz, UtahYork, Jon G, Ole49GMC, 1 invisible),
106
Mod | | | Forums66 Topics128,134 Posts1,056,740 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 31 New Guy | | New Guy Joined: Aug 2009 Posts: 31 | My stock gauges are a total loss. Any recommendations on companies that have aftermarket three gauge sets with the large speedo and two smaller double gauges? As always you guys info and assistance is appreciated.
Oldbald2
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Oldbald2 ,there is a fellow bolter that rebuilds gauges I do not remember His name but if You do a search I'm sure You'll find Him.
Good luck ,Pete | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | You can also check Hemmings Motor News. There are several gauge rebuilders who advertise regularly.
| | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | in the tech area there is a artical for using a set of gauges from a 260z i have a 39 and have been told they are the same for 38 and a direct fit/replacement
1937 1/2 ton
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | oldbald2: Daniel is correct about the Z guages but I don't think they made a 260Z...did they??? Anyway, I have a set I took out of a 280Z and they do work. You take the chrome bezel off the original guages and press them over the rim of the Z guages and your set to go. The press is a tight fit and works well. I wish I had known this back when I did my 37. I paid $365 to get my guages re-done back in 1999. There is a local place here in Greenville S.C. that does a great job. D&M Restorations 864-421-9959 I did NOT get the speedo but from my understanding they work with just a LITTLE modification. Bingo, 12 volt guages to.
I might add that several years of Z guages will work. The difference is in the colors. You know, black background red markings....white background red markings and so forth. Depends on the year they come off of. Mine are black with red markings. | | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | btw should mention the small ones are set up same as the guages you have now only modern
1937 1/2 ton
| | | | | Joined: Aug 2009 Posts: 31 New Guy | | New Guy Joined: Aug 2009 Posts: 31 | Guys thanks for all the info. It looks like I can go one of three ways, have originals rebuilt, datsun 260/280z original guages, and aftermarket new vintage style gauges. Decisions, Decisions. Thanks for help again
oldbald2 aka Don | | | | | Joined: Mar 2010 Posts: 3 New Guy | | New Guy Joined: Mar 2010 Posts: 3 | Hello i have just joined the stovebolt family here, My dad and i was wanting to redue our orig gauges, and then found this post, and i began to search and lowbehold, i found some on ebay, i bought the gauges for 60 bucks, verses 750 to get the orig redone, now waiting on them. if you want there are more on ebay. just want to let you know. anyway, good luck and just to let you know i am building a 38 chevy pickup my self. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 |
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
