0 members (), 80 guests, and 1 robot.
Topics128,049
Posts1,055,741
#611918 01/21/2010 1:19 AM
i recently checked the oil in my '46 chevy 2 ton and found the oil to be a grayish cloudy color does this mean anything? is it bad? good?
Emory
the 2nd ammendment is in place incase the politicians ignore all the others
It might mean water in the oil. Does it run? If so change the oil and run it some more to see what is going on.
Does it make noise? If it does you may need to go slower checking it out...
3B Offline
Hy Elieber, it usually indicates that coolant has been allowed to mix with the oil, and the engine was run after that happened. I would not run that engine with that mixture in the pan. The most likely cause is a blown head gasket, but it can also occur if the engine is overheated and develops an internal crack in the block or head. It looks like you have some detective work to do.
....this can also happen if you only make short runs in it and the engine never gets up to operating temperature. Then when you cut it off you get condensation. I'd change the oil and make sure it reaches operating temps each time you start it up and re-access.....
if you want a quick check for blown head gasket fill the raidator up and with the cap off watch the water to see if it bubbles...after it warms up and the water is circulating.
How old was the oil you check?
How have you been driving the truck?
Hows the weather, Humid? Dry?
Just change it out and go about your business. I am with Alvin, short trips are really hard on engines. It you start it, drive it till its good and hot, other wise leave it off.
My alcohol burning race car used to get water in the oil real bad due to the condensation and short runs. Each week I would drain a cup or two of water out of the oil pan before heading to the track.
Joe
