Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (Peggy M, 68ironhead, TUTS 59, Bill Hanlon, Hambone), 72 guests, and 2 robots.
Topics128,009
Posts1,055,296
Members48,419
#61172 05/31/2006 6:38 PM
I'd like to switch the starter from a foot pedal to a key operated one on my 54 chevy truck. Still running the original 235. I was thinkin that maybe there was a "retro" fit on the market?
Ole B97
#61173 05/31/2006 7:03 PM
60-62 235 trucks had the key start or starter and key sw from that era car will do it - not sure if the ring gears are different, but a search here should turn something up, it's been discussed
#61174 05/31/2006 7:25 PM
Bill, I'm pretty sure that they're the same.
#61175 05/31/2006 7:26 PM
If your truck is still 6 volt the starter from a 1949-54 passenger car will fit right on. You will have to change the ignition switch to one with a start position or use a push button.
My Blog
#61176 06/01/2006 12:36 AM
Ther is a diference between the 6 volt and 12 volt fly wheels. If you use the six volt key starter on 12 volt you need to use a 12 volt solinoid.
