6 members (RoadsScholar, baldeagle, MickeyP, Stovebolt48, Otto Skorzeny, 1 invisible), 177 guests, and 4 robots.
Topics128,108
Posts1,056,231
Members48,436
Do you bother to replace clutch head screws with new ones, or do you go with something a little more modern?
"Happiness equals reality minus expectations" - Tom Magliozzi
most of my truck has hexhead bolts,but the rear fender bolts in the box are clutch head,for appearance
Jim,
I am trying to use clutch heads everywhere I can that is visible-(fender, door striker and latch,etc), cleaning some old ones, buying some new ones. (If anyone has some they want to get rid of.
Mike
My old truck's still running good, my ticker's ticking like they say it should, I got supper in the oven, a good woman's loving, and even my bad days aint that bad...Yeah, I'm a lucky man!
1953 Chevy 3100 Shortbed
1965 C-30 Panel Truck
1963 C-20 Long/Fleet Pick-up California Black Plate
I replaced the screws on the gas tank sending unit with Allan heads because the are easier to get off if needed... The old clutch heads screws were rusted and stuck... I probably would replace certain clutch head screws with the same...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
without a set of clutch head drivers they are a pain to work with. after i got the three driver set, i like them better than flat or phillip heads. i have yet to have a head strip out. i too like them for appearance
I'm trying,where possible,to replace mine with stainless button head bolts/screws.
If I go to a hardware store here and ask for clutchheads,they look at me as if I had horns or something.
Or maybe it is just the way I look....... eek
I 'loaned' out my clutch head drivers, never got them back. :mad:
More pix on Flickr.
I replace mine with clutch head, since they are what was original, plus I like to look.
Samantha
1954 Chevy 3100
Picked from the Field
Follow in the DITY
