6 members (Hotrod Lincoln, GMCJammer51, jmoore, Forty9, 2 invisible), 117 guests, and 1 robot.
Topics128,196
Posts1,057,385
Members48,469
Will I be able to find a short driveshaft for a C10 that will accomodate the factory 4 speed behind the 283 I pulled from a donor?
The donor was a long bed and has the slip yoke 2 piece shaft design.
The truck it's going in is a 2WD 1964 C10.
Thanks in advance.
rg
She's one half rock and the other half roll...
I know they are available, I sent one to scrap about 2 weeks ago,,try RJ or 456 chevy on the swap meet.brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Probably cheaper to take it to a driveshaft shop or just a machinist and shorten the one you have.
I did.
Didn't think of those guys... thanks 64FS.
How much did you cut out and from which shaft Gazim??? I'm guessing front shaft for the cut. Carrier mounting should be the same long to short. Right?
rg
