0 members (),
118
Mod | | | Forums66 Topics128,196 Posts1,057,393 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#61061 05/29/2006 2:50 PM | Joined: Mar 2006 Posts: 10 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 10 | Will I be able to find a short driveshaft for a C10 that will accomodate the factory 4 speed behind the 283 I pulled from a donor?
The donor was a long bed and has the slip yoke 2 piece shaft design.
The truck it's going in is a 2WD 1964 C10.
Thanks in advance. rg
She's one half rock and the other half roll...
#61062 05/29/2006 3:57 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I know they are available, I sent one to scrap about 2 weeks ago,,try RJ or 456 chevy on the swap meet.brian | | |
#61063 05/29/2006 4:24 PM | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Probably cheaper to take it to a driveshaft shop or just a machinist and shorten the one you have. I did. | | |
#61064 05/29/2006 4:37 PM | Joined: Mar 2006 Posts: 10 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 10 | Didn't think of those guys... thanks 64FS.
How much did you cut out and from which shaft Gazim??? I'm guessing front shaft for the cut. Carrier mounting should be the same long to short. Right? rg
