7 members (DaveV, wilbur53, Gdads51, Joe H, tclederman, KEVINSKI, 3B),
128
Mod | | | Forums66 Topics128,281 Posts1,058,473 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 43 Apprentice | | Apprentice Joined: Jan 2010 Posts: 43 | Hello all, This my first post so be kind. I just bought a 1962 Stepside and would like to put in a new 1964 CHROME aftermarket grill. Do I need to buy their $300 Grill Support Panel for a 64-66 to make it work, our can I do a little improvising and make it work?
Great Site by the way | | | | | Joined: Jan 2008 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 69 | Welcome to the site. The 64-66 grille should bolt right in. Good luck.
TruckNut
Be kind, courteous, cheerful and helpful - And someone will take advantage of you.
"Quiting smoking is easy, I've done it hundreds of times." Mark Twain
| | | | | Joined: Mar 2005 Posts: 189 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 189 | you will have to drill a few holes to match up to the 64 grill but other then that it will work. | | | | | Joined: Jan 2010 Posts: 43 Apprentice | | Apprentice Joined: Jan 2010 Posts: 43 | Thanks for the QUICK replies. I thought it should, just noticed when I went to order the grill the sales guy said you had to replace the support (NOW THAT'S A GOOD SALESMAN | | | | | Joined: Jan 2008 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 69 | RJ, which holes are different? I've seen the 64-66 grills put in all years of these trucks, but I don't remember if I ever swapped one myself. I do remember I put a '65 grill support on my '61, and the bolts that go through the support fit the '61 grill without having to re-drill them. Are the holes in the fenders different? Sorry if I mis-informed him.
TruckNut
| | | | | Joined: Jan 2008 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 69 | Now that I think about it, I believe only the outer holes lined up, and they go through the support too, not through the fender. I just remember having to go from under the fender to get to the outer bolts. Sorry, it's been a while. My CRS is kicking in.
RJ, I see you are aquainted with Tony Smith at 4-5-6 Trucks. I've talked with him a couple of times on another site. Super nice guy.
TruckNut
| | | | | Joined: Mar 2005 Posts: 189 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 189 | some grills have four holes and some are three holes to mount to the filler panel, yes Tony is a friend and Customer, we swap parts and info all the time. any info is good. i learn stuff about these trucks all the time. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | The '60-'61 grille supports have the same grille assembly mounting holes. The '62 & '63 are different from each other and the 4-5-6 are the same for all three years. The grille assembly mounting brackets have the weld nuts attached to them, therefore, if installing a different grille assembly on another year grille support, you only need to redrill holes in the grille support (not the fenders) for proper alignment and securing the grille assembly.
In summary, all the grilles will interchange, somewhat, minus drilling a few additional holes.
TruckNut and RJ, thanks for the kind words. | | | | | Joined: Mar 2009 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 100 | great advice, i am changing a 63 onto a 65
It's better to have it and not need it, then it is to need it and not have it. "Woodrow F. Call"
| | | | | Joined: Jan 2010 Posts: 43 Apprentice | | Apprentice Joined: Jan 2010 Posts: 43 | Thanks for the help. One other problem that I ran into.... YOU NEED TO REPLACE/BUY/BORROW/STEAL New Headlight Buckets!!! or it's not going to work. You need the Buckets if you buy a new grill, because they don't come with, and the '62s won't work. I had to buy a new set from LMC at about $140 with shipping! This grill change is getting real expensive, and I'm not even finished yet :-(
| | | | | Joined: Jan 2010 Posts: 43 Apprentice | | Apprentice Joined: Jan 2010 Posts: 43 | Well, just finished the Grill Installation... not to difficult, only few cus words. The top bolts line up, but you need to drill (2) other holes on each side to attach. I had to use a longer bolt for the bottom mounts,and it doesn't mount flush to the Grill Support - about a 2" gap, not to noticeable but I know it's there! All in all, I guess where there's a will there's a way! | | | | | Joined: Mar 2002 Posts: 23 New Guy | | New Guy Joined: Mar 2002 Posts: 23 | I think the 62 is one of the best looking of all the years did you consider just chroming the one from your 62? also there are some that are aluminum that you could just polish out and the others are painted steel. Bob | | |
