3 members (Cosmo, LAROKE, 1 invisible),
51
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#60957 05/26/2006 8:45 PM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | What is the advantage of running your 2 exhaust pipes from the header into 1 pipe?
Quiter? Cheaper?
I know alot of newer manufacturers take 2 into the catylitic converter, and 1 or 2 out. This generates more heat and aids the converter in doing its job more efficiently, but this doesn't apply to old trucks.
Oh yeah... 302 gmc 6 with fenton dual exhaust in 1940 gmc 3/4 ton. | | |
#60958 05/26/2006 10:28 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The only advantage I would see is clearance problems. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#60959 05/26/2006 11:10 PM | Joined: Dec 2003 Posts: 510 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 510 | I figger this has to be economics. Single exhaust has been the "standard" since times were better. One tailpipe, one muffler, etc. Costs less to produce and less to maintain. Dual exhaust was almost always an option, unless it was part of the performance package as in the case of the Olds 442 (4-barrel, 4 speed, dual exhaust.)
Long ago I was told that the best thing I could do to improve the performance of a Chevy V8 was to get rid of the "strangulation" single exhaust and add headers and duals. I dunno how much truth there is to it, but that was the conventional wisdom of the day (a long time ago.) | | |
#60960 05/27/2006 3:44 PM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | I've read that the performance advantage from dual manifolds/split manifolds is maximized after about 3 feet of pipe- after that two pipes/two mufflers are for looks and sound. If you want two pipes you should 'x' them at the cross member. If not, 'y' them at the cross member.
#60961 05/27/2006 4:31 PM | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Anybody know +- on a 2 in, 2 out muffler?
40 Chevy 1/2 ton
#60962 05/27/2006 4:47 PM | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | Well... a plus is that it sounds SO good  Of course since I have one I just may be biased. | | |
#60963 05/29/2006 4:43 PM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Thanks for your help. Read about this setup in a couple of posts | | |
#60964 05/31/2006 4:27 PM | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | Dennis M, I have a 2 in 2 out muffler on my '32 bolt. I made it myself when I worked at a muffler shop many years ago. Jaguars had a similar muffler on the 6 cyl. cars, also I have seen a 2 in 2 out muffler advertised in some of the street rod magazines. It makes a unique sound still the split 6 rap but subdued. I think mine sounds great. | | |
#60965 05/31/2006 6:17 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I did twin 2" from the Fenton to under the cab where I used a single 2.5" inlet muffler with twin 2" outlets. A stock muffler was used to subdue the noise to what I consider respectful. I don't know how this would compare to a 2x2 setup but it sounds great (to me) and looks terrific with the twin chrome tips and was inexpensive. I looked into the 2x2 setup but was unable to find a muffler that was the proper size and shape but am delighted at how it all turned out regardless. This truck is for my wife who likes the sound a bit quiter than I might prefer but it is still OK. The worst part was making the two into one pipe ahead of the muffler. | | |
#60966 05/31/2006 11:21 PM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | Flowmaster makes a flat 2 in 2 out muffler and dynaflow makes a round one that looks like the factory muffler in the truck.
The dynaflows are more like 2x2 glass packs, and in my opinion (no offense intended to anyone...) sound like a rice burner auditioning for fast n' furious.
