2 members (Hawkman, 52GMC35424JD), 97 guests, and 1 robot.
Topics128,051
Posts1,055,768
#602963 12/21/2009 12:36 AM
rar
Offline
i would like to change my dist out for a later model so i could do away with points. my engine is a 65 gc 230 6 cly. where might i find what i need and what all is involved in installing. is the 230 different than the 235? thanks alot. rar
Riding in the Passing Lane
The 230 is a whole new animal from the 235 that was dropped in 1962.The best ign for it is the HEI that came on the 78 models up into the 80's. The 75-77 will work good too, but the coil is separate from the cap. One from a 250 or292 will fit. Go into it & make sure the mechanical & vacuum advance are working good. Run a 12 gauge wire from the bat connector to the pink wire on the back of the ign. switch. Install it in the normal way to install a dist.
1972 Chevy c10 Cheyenne Super
rar
Offline
thanks. i appreciate the info. rar
I have used this one successfully. I went back to original look (small distributor) by using a Pertronix unit.
http://www.stoveboltengineco.com/acartpro/product.asp?productid=125
Id be all over that unit from Langdon's stovebolt, you get the complete distributor and coil for just under $100 and an expert like Landgon to hold your hand, what a deal.
1946 1/2-Ton Chevy
Langdons unit works well
Thanks for posting this. I ordered mine today!
rar
Offline
thanks, know what to get now. love this forum. really helps out. rar
