5 members (Otto Skorzeny, Woogeroo, klhansen, 2-Ton, TUTS 59), 77 guests, and 6 robots.
Topics128,193
Posts1,057,241
Members48,465
just another thing im tryin to get out and replace but got stuck.haha. i have the whole seat fame out,the straps holding the gas tank down are removed, the filler and vent hose is disconnected,the fuel line from under the cab is removed from the tank....yet the thing still feels like its bolted in. any other things holding this tank in?
Dan
U
U Offline
Dan,
Can you check your assy manual to see what could be holding it down?
My 57 had the 2 straps and that was it. Not sure if our tanks wold be the same set up though. Good luck!
1957 Chevy 1/2-Ton Truck
More pix
The coldest winter I ever saw was a summer I spent in San Francisco M. Twain
If at first you don't succeed...skydiving is not for you!
If you don't like my carbon foot print, stick it up your Prius!!
7
7 Offline
I just took mine out of my 50 GMC and did everything you did. It needs a good whack with the palm of your hand a couple of times to unseat it from the lower cradle. There is nothing else holding it in. Make sure you have removed the shut off valve under the tank.
There is a rubber pad under the tank right at the draw pipe that sticks to the tank and the bottom of the cab. I'm not sure if they were glued at the factory or just became stuck after 60 years. I little wiggling should get it loose.
There's that rubber that crenwelge mentions and there may still be two rectangular pads that isolate the tank from the straps, probably to prevent rattling as well as wear
to the tank.
If you grab it with both hands and rock it firmly it should break loose.
Any pads and rubber seals just get gummy and adhere after many years.
Ray
alright thanks.ill go give it a good beating and report back.
thanks,
dan
I think the pad on the bottom has a tar like substance on it. The heat melts it and then it sticks to the tank. It's been 3.5 years since I removed mine but I agree with the rest here, get mean with it.
~Jim
Oldog in Md.
Unregistered
Oldog in Md.
Unregistered
BFH
a bit of gas in the tank and a road flare would remove it, however it would be a bit hard on the rest of the vehicle. My 53 came out with a pry from a piece of wood and a whack with the rubber mallet (my tank is in good shape, just needed to pull it to clean out the rat poop)
Like Crenwelge said "wiggle" don't beat it up too much.
1951 restoration on website
http://www.hanklong.com
Y
Y Offline
I know you mentioned You removed the fuel line- Was there a valve or a fitting that you might have missed that it is catching on?
1949 Chevy 4400 Big Red
1949 Chevy 3600 Bob's Truck
1949 Chevy 3100 The Investment
1949 Chevy 3800 the Won Ton
