2 members (52Carl, Gdads51),
37
Mod | | | Forums66 Topics128,180 Posts1,057,161 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 35 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 35 | dynamat and hush mat are too expensive it seems. i have found some reasonable competetors with good reviews on e-bay. what do you guys think?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=280448949056&ssPageName=STRK:MEWAX:IT
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=320470815973&ssPageName=STRK:MEWAX:IT
| | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Go to your local home center or lumber yard. Buy a roll of Peel & Seal. Works as well as the expensive stuff at a fraction of the cost. (plus you can patch your roof with what's left over)
| | | | | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | You may get replies that it will smell like roof tar when it heats up or that it may not stick well when it gets really hot but its been fine in mine. Bought mine at a local roofing supplier. I used 3m adhesive to intall it and then used the metalic silver tape for the joints. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | Don't buy the kit from LMC, i did and it was dried out and broken. it is made of petroleum by products. rather than send it back i threw it away. i did use the carpet padding looking stuff and it works very well. i have also used the peel and seal and heat will make it let go, so use it on flat surfaces or use extra glue. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | Used peel & seal on inside of doors, floorboard, and behind gas tank 7 years ago--special ordered it at Menards. Applied over clean primered surface, adhered well, never came loose, worked well to reduce noise and have never experienced the smell. Very well pleased with the result. Would do it again in a heartbeat. | | | | | Joined: Nov 2008 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 101 | Does anyone know if there are any stats that ACTUALLY say that Peel & Seal is as good as Dynamat? Not that it matters that much but I'd be happy if it were just close to being as good.
As for using it on the underside of my roof, would it work if I put it up over a rust encapsulator using the self adhesive it comes with, THEN using the silver metallic tape that Shea mentions above on each edge, then putting the next piece up? Also, I noticed via the link, it comes in 6 inch wide strips or i 33-1/2" wide strips. It seems like the 33-1/2" stuff would be a pain to try to apply it to the roof. | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | You can get it in several widths at the lumber yard. It should stick well to about any clean surface. It's made to stop ice damming and flash around doors and windows. It seals nails driven through it. As for stats, all I've read about using it on vehicles has been anecdotal evidence like that from 56picup.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Used to be an excellent comparison on this site http://www.sounddeadenershowdown.com/Now he sells the stuff. Wish I could find the old article/test results, done very simply and easy for the average guy to understand, and easy to see why the real stuff is preferred even if it cost more. Last time I read the comparison Second Skin was #1, for quality vs. price. But it's been several months now. Grigg | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I too used the Peel & Seal - 6" wide for my cab. I did the floors, cab, roof, and doors. Easy to cut and fit. Sticks pretty well on clean metal. No smell, even on a hot day. Does it perform as well as Dynamat ??....probably not, but it cost me about $ 80.00 to do the whole truck ! | | | | | Joined: May 2010 Posts: 1 New Guy | | New Guy Joined: May 2010 Posts: 1 | I use and sell Fat Mat in my shop . Great bang for the buck .
Stitcher Bennettsupholstery.com | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I used this stuff sound deadener 32x54 $38.00 roll Not as thick as the expensive stuff but it was easy to apply and afforadable a few pics The supplier is out of Arizona and NOT a chevy supplier.
| | | | | Joined: Jun 2011 Posts: 63 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 63 | DADS50: About how many rolls did it take to insulate your truck? Thanks. Charlie | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | I used Reflectex from Home Depot about 20 bucks a roll. Used a 3M contact cement to hold in place. Seems to work OK and takes away some of the "tinny" sound. Pics start here. Have fun and good luck Dan | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | DADS50: About how many rolls did it take to insulate your truck? Thanks. Charlie I dont recall how many rolls, It was over a year ago. I used it on the firewall, cab roof, rear of cab, and placed some extra material in the doors. maybe 2 Its peel and stick. works well as long as the surface is clean Good Luck | | |
