7 members (R&S 51 GMC, Otto Skorzeny, crenwelge, Hotrod Lincoln, 1955 1 Series, Tronman, Wrenchman),
194
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,125 Posts1,056,341 Members48,440 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 313 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 313 | The Rochester 2G on my 283 needs to be replaced, and I have located one for a 1967.
Is it the same as the 1966? | | | | | Joined: Feb 2004 Posts: 29,810 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,810 | As long as they're both for 283 engines, chances are they will interchange. If you've got the tag numbers from both carburetors, I can probably research any differences in my shop library when I get to school on Monday. Once a Rochester loses the triangular sheet metal tag that's supposed to be under one of the bowl cover screws, it can be very difficult to identify what it's supposed to fit. Some of the later-model carbs will have a number stamped into the main housing, but I don't remember what year they began to do that. Jerry
| | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | The bowls were stamped beginning in 1968.
1966 and 1967 should interchange as long as both from the same type transmission engine (either auto or stick), and type of vehicle (either truck or car).
The auto carb may be used on the stick vehicle; but the stick carb should NOT be used on an auto vehicle.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Apr 2005 Posts: 313 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 313 | The number on the 1967 carburetor is 7037105. | | | | | Joined: Apr 2005 Posts: 313 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 313 | I have solved my problem, and I will not need to replace the carburetor.
