| | | Forums66 Topics128,022 Posts1,055,387 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 75 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 75 | so i know the speedo works but the other gauges were not functioning when i bought the truck, is there anyway to test and see if they were just wired poorly or should i trash and replace them or can i get them rebuilt? | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Take them out and give them a good cleaning and inspection. Be very careful with the tube connected to the temp gauge, it is gas filled and if you break it it will never work again. The gas and amp gauges will most likely just have bad connections or broken wires somewhere. If you want new gauges then you can get them from Jim Carter or American Classic see the links on the home page of stovebolt. | | | | | Joined: Dec 2008 Posts: 75 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 75 | thanx and btw grats on your truck i forgot to say that before | | | | | Joined: Jul 2007 Posts: 293 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 293 | If you have an air compressor, set the compressor on 30 psi and blow it into the end of your oil pressure sensor. The oil pressure gauge should be fairly accurate whether it's measuring oil or air. Mine is anyway. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The gas gauge should register full when powered up with no sender attached. When you ground the sender lead it should register empty.
The ammeter is easy to test. Hook it up in series with a load and see that it registers. Reverse the polarity to test the opposite direction.
The temperature gauge can be tested with a pot of boiling water.
| | | | | Joined: Dec 2008 Posts: 75 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 75 | Thanks for all the advice | | |
