| | | Forums66 Topics128,281 Posts1,058,472 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 4 New Guy | | New Guy Joined: Dec 2009 Posts: 4 | hey i was just wondering what bellhousings would match up to my 235 without the hydrolic clutch slave cylender on the right. i jus want a manual clutch cuz the truck its goin in dont have that master cylender. and i was wondering if i could used the clutch and for and flexplate off my old 402??
| | | | | Joined: Jan 2008 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 69 | What are you putting it in? If you need the two mounts under the bell housing then you should be able to use a 235 housing for a 55-59 truck. The 235 car housing is mechanical also but does not have the mounts. The 402 clutch may work, but I don't think the flywheel will work. As I recall the 235 has the timing marks on the back of the flywheel. Hope that helps.
TruckNut
Be kind, courteous, cheerful and helpful - And someone will take advantage of you.
"Quiting smoking is easy, I've done it hundreds of times." Mark Twain
