Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Otto Skorzeny, 55shaker, Ribside), 128 guests, and 5 robots.
Topics128,281
Posts1,058,478
Members48,490
#608858 01/10/2010 7:46 PM
hey i was just wondering what bellhousings would match up to my 235 without the hydrolic clutch slave cylender on the right. i jus want a manual clutch cuz the truck its goin in dont have that master cylender. and i was wondering if i could used the clutch and for and flexplate off my old 402??
kdawg #609155 01/11/2010 5:59 PM
What are you putting it in? If you need the two mounts under the bell housing then you should be able to use a 235 housing for a 55-59 truck. The 235 car housing is mechanical also but does not have the mounts. The 402 clutch may work, but I don't think the flywheel will work. As I recall the 235 has the timing marks on the back of the flywheel. Hope that helps.
TruckNut
Be kind, courteous, cheerful and helpful - And someone will take advantage of you.
"Quiting smoking is easy, I've done it hundreds of times." Mark Twain
