Brrrr
place holder
6 members (Bill Hanlon, UtahYork, Ponchogl, Otto Skorzeny, 55shaker, TooMany2count), 320 guests, and 3 robots.
Topics128,272
Posts1,058,419
Members48,485
#609064 01/11/2010 10:04 AM
7
Apprentice
Apprentice
7 Offline
OK, So we went and visited the truck again...
Seems the shifting pattern is:
1-3
-N-
R-2-4
Which is weird as the shifting pattern on my F-350 is:(Wich is normal)
1-3
-N-
2-4-R
The truck had a in-cab tank, which has been removed, I didn't find this out until yesterday.(Which is fine by me, as it has a saddle tank on both sides) (Which isn't factory)
{I took more pictures)
Now for pictures:
[IMG]http://i742.photobucket.com/albums/xx67/76_SCS_Lover4/59%20Chev%20One%20Ton/fc7dfc7b.jpg[/IMG]
The Dual Rear Wheels:
[IMG]http://i742.photobucket.com/albums/xx67/76_SCS_Lover4/59%20Chev%20One%20Ton/2fc537ef.jpg[/IMG]
The passenger side Non0Factory Saddle Gas Tank:
[IMG]http://i742.photobucket.com/albums/xx67/76_SCS_Lover4/59%20Chev%20One%20Ton/fa7104bd.jpg[/IMG]
Here is me sitting in the truck:
[IMG]http://i742.photobucket.com/albums/xx67/76_SCS_Lover4/59%20Chev%20One%20Ton/f80b039b.jpg[/IMG]
Here is my dad sitting in the truck:
[IMG]http://i742.photobucket.com/albums/xx67/76_SCS_Lover4/59%20Chev%20One%20Ton/4ff39832.jpg[/IMG]
Here is the worst of he rust issues, all in all not bad:
[IMG]http://i742.photobucket.com/albums/xx67/76_SCS_Lover4/59%20Chev%20One%20Ton/fba7984d.jpg[/IMG]
'76 F-350 Super Camper Special (140" WB), Ranger-XLT, Fast 390 V8, 4-Speed, Gun Rack, Brush Guard, Dual Exhaust, 3.73 Gears, 10K GVW.
'74 F-250 Super-Cab (155" WB), Ranger, Rebuilt 390 V8, C6 Auto, Tachometer, Headers, '77 Grille, Kill Switch, Single Exhaust, 4.11 Gears.
'59 Chevy 38 Apache Stakebed (Not running), 235-Inline-6, 4-speed, Gun Rack, 3 Tanks, Dual Rear Wheel, 9.5K GVW & no fancy stuff.
'99 Mitsubishi Fuso 5-Ton Delivery Truck, Diesel, 4-Speed Auto, 1-Ton Lift Gate, 18FT Box.
7
Apprentice
Apprentice
7 Offline
7
Apprentice
Apprentice
7 Offline
7
Apprentice
Apprentice
7 Offline
Exterior:
[IMG]http://i742.photobucket.com/albums/xx67/76_SCS_Lover4/59%20Chev%20One%20Ton/fb37f3e9.jpg[/IMG]
[IMG]http://i742.photobucket.com/albums/xx67/76_SCS_Lover4/59%20Chev%20One%20Ton/ce6b94fe.jpg[/IMG]
[IMG]http://i742.photobucket.com/albums/xx67/76_SCS_Lover4/59%20Chev%20One%20Ton/e35b28c3.jpg[/IMG]
Interior: This picture raises a question to me...What are those too little cut-out things on either sides of where a radio would be on this truck, see ;em, there's two. I thought one was a ash tray...
[IMG]http://i742.photobucket.com/albums/xx67/76_SCS_Lover4/59%20Chev%20One%20Ton/72d96b17.jpg[/IMG]
(As you can see we cleared off all the wood on the seat)
Exterior Fender:
[IMG]http://i742.photobucket.com/albums/xx67/76_SCS_Lover4/59%20Chev%20One%20Ton/0198aab2.jpg[/IMG]
Exterior Passenger:
[IMG]http://i742.photobucket.com/albums/xx67/76_SCS_Lover4/59%20Chev%20One%20Ton/8283b674.jpg[/IMG]
Hasn't been registered sense '74. (Still has the original Black CA Plates.)
The rear differential:
[IMG]http://i742.photobucket.com/albums/xx67/76_SCS_Lover4/59%20Chev%20One%20Ton/cc015208.jpg[/IMG]
7
Apprentice
Apprentice
7 Offline
The Bed: Which is exactly 9-Feet Long, and 8-Feet wide, Exactly, no inches or anything...
[IMG]http://i742.photobucket.com/albums/xx67/76_SCS_Lover4/59%20Chev%20One%20Ton/f5d83ccc.jpg[/IMG]
Steeringwheel emblem:
[IMG]http://i742.photobucket.com/albums/xx67/76_SCS_Lover4/59%20Chev%20One%20Ton/11a618fd.jpg[/IMG]
Here, You can see those little boxy panels that I am wondering what they are, the one on the right appears to have had a switch on it?
[IMG]http://i742.photobucket.com/albums/xx67/76_SCS_Lover4/59%20Chev%20One%20Ton/a8550853.jpg[/IMG]
The Bed 2:
[IMG]http://i742.photobucket.com/albums/xx67/76_SCS_Lover4/59%20Chev%20One%20Ton/0b69791a.jpg[/IMG]
The GloveBox:
[IMG]http://i742.photobucket.com/albums/xx67/76_SCS_Lover4/59%20Chev%20One%20Ton/e45518d0.jpg[/IMG]
See the E-Brake?
It's-Ton+!
[IMG]http://i742.photobucket.com/albums/xx67/76_SCS_Lover4/59%20Chev%20One%20Ton/1a3c9a2d.jpg[/IMG]
Outside Cab Fender:
[IMG]http://i742.photobucket.com/albums/xx67/76_SCS_Lover4/59%20Chev%20One%20Ton/4d1b7e6d.jpg[/IMG]
(No I don't know who's Beer Bottle That is...It's not mine...)
The Top of Valve cover:
[IMG]http://i742.photobucket.com/albums/xx67/76_SCS_Lover4/59%20Chev%20One%20Ton/d1da4901.jpg[/IMG]
Every Picture in here, is new & never before seen.
Thank You for looking at my truck!
Thank,
Anthony.
That is the normal shift pattern for a SM 420 4-Speed in a Chevy or GMC. That transmission was used for many many years up until about '68.
...your just not used to an old Chevy yet!!
BTW, I've seen Reverse everywhere. I had a '62 GMC 5-Speed and Reverse was Up and to the Right.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
7
Apprentice
Apprentice
7 Offline
So that is where Reverse is?
Did ya look at the links, I posted...?
To answer the question about the two boxy sections on the dash; the one next to the ignition switch is the ashtray. Pull out at the top to tilt it out. They can be somewhat stiff. If you push down on the snuffer (the "ring" on the top whenyou pull the ashtray out), then continue to pull on the top, it will come out of the dash. That was to allow for cleaning it put. The other one next to the glocebox door is a filler plate. On trucks with the deluxe heater, the controls, which are similar to the '55-'56 Passenger controls, would go in that hole. Base heater or delete option trucks got the blank off plate. Since that one has a switch in it, it looks like it got a dealer installed heater. That was a common place for them to put the switch either dealer install or aftermarket (my '55 was the same way).
Bill Burmeister
7
Apprentice
Apprentice
7 Offline
Thanks for the info.
This truck has been sitting for God only knows how long, and the ash tray seems to not want to move...
Was last updated on the stickers in '74.
My dad just called me on the phone & told me he pulled the seat out of the truck. (I'm not with my dad at the moment)
And he said he found all the tools from the factory to work on the truck, such as the tire iron etc..
Also found some magazines from '67.
As well as a rat & this rat, made it's nest in the seat. (Which is why my dad pulled it, to have it recovered & cleaned good)
He also found one orginal mirror for the truck, under the seat.
Next time I go out there, I'll take pictures of what he found...
Moderated by  Dusty53
