| | | Forums66 Topics128,204 Posts1,057,288 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 75 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 75 | so i bought a manual and it is really confusing is the puller a universal one? can i make one from garage scrap? anyone have any plans or advice on making one or pulling the steering wheel or for that matter the steering box this will be my first one | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | I used a generic puller on mine. It was on there pretty tight and I had to use a big hammer too. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I don't have a GMC or a GMC manual but isn't it the same as the Chevy steering wheel????? Simply use a steering wheel puller on it like you're supposed to. You're probably looking at the mast jacket bearing puller. Yes that puller is a tapered piece that has hardened threads on its outside, (kind of looks like a great big tapered pipe tap) and is screwed into the bearing shell then the center bolt is used to pull it out of the mast jacket. Please, no need for hammers here, try leverage, remember this old saying; “Give me a place to stand and with a lever I will move the whole world.” Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think there was also a question about the steering box. To remove the Pitman arm you need a fairly heavy duty puller. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Gues that's just my deslexia rearing it's head Fred. Dint see that part of the question. In fact that doesn't even look like the same question that I was trying to answer. I seem to recall something about a cone shaped puller and don't recall the part about the box???? Denny Graham Sandwich, IL
