6 members (tclederman, kades51, wilbur53, UtahYork, Ridgeback, 1 invisible), 72 guests, and 8 robots.
Topics128,187
Posts1,057,211
Members48,465
so i bought a manual and it is really confusing is the puller a universal one? can i make one from garage scrap? anyone have any plans or advice on making one or pulling the steering wheel or for that matter the steering box this will be my first one
1953 GMC 3/4-Ton Truck
Wanna know more about me heres my Myspace
I used a generic puller on mine. It was on there pretty tight and I had to use a big hammer too.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
I don't have a GMC or a GMC manual but isn't it the same as the Chevy steering wheel????? Simply use a steering wheel puller on it like you're supposed to.
You're probably looking at the mast jacket bearing puller. Yes that puller is a tapered piece that has hardened threads on its outside, (kind of looks like a great big tapered pipe tap) and is screwed into the bearing shell then the center bolt is used to pull it out of the mast jacket.
Please, no need for hammers here, try leverage, remember this old saying; “Give me a place to stand and with a lever I will move the whole world.”
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
I think there was also a question about the steering box. To remove the Pitman arm you need a fairly heavy duty puller.
1951 1 Ton Completed
Gues that's just my deslexia rearing it's head Fred. Dint see that part of the question. In fact that doesn't even look like the same question that I was trying to answer. I seem to recall something about a cone shaped puller and don't recall the part about the box????
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
