1 members (Ole49GMC), 109 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
The Rochester 2G on my 283 needs to be replaced, and I have located one for a 1967.
Is it the same as the 1966?
As long as they're both for 283 engines, chances are they will interchange. If you've got the tag numbers from both carburetors, I can probably research any differences in my shop library when I get to school on Monday. Once a Rochester loses the triangular sheet metal tag that's supposed to be under one of the bowl cover screws, it can be very difficult to identify what it's supposed to fit. Some of the later-model carbs will have a number stamped into the main housing, but I don't remember what year they began to do that.
Carburetion specialist
The bowls were stamped beginning in 1968.
1966 and 1967 should interchange as long as both from the same type transmission engine (either auto or stick), and type of vehicle (either truck or car).
The auto carb may be used on the stick vehicle; but the stick carb should NOT be used on an auto vehicle.
Jon.
The Carburetor Shop
The number on the 1967 carburetor is 7037105.
I have solved my problem, and I will not need to replace the carburetor.
