| | | Forums66 Topics128,009 Posts1,055,291 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 293 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 293 | The driver's side window on my '49 1/2-ton stays up while the truck is standing still, but works its way down while driving. Is replacing the spring in the window regulator a weekend project? I've also noticed that the window is not square to the frame. One edge of the window reaches the top before the other when rolling the window up. The regulator has elongated holes where it is mounted to the door, but no matter how I install the regulator, the window does not track squarely in the window frame. This doesn't seem right. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Probably finding a replacement spring will be the project. I suggest checking the swap meet or placing a want ad for another regulator. Also the vendors (see the home page) will likely have reproduction ones. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | It sounds like you have more than one problem going on. I would think that you would want to replace the track at the same time you repair the regulator. If it were me I would try and get another assembly. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | norcal...As the other guys have said,it might be an idea to try and locate a replacement. It sounds like things are very worn, the drivers regulator would more than likely get the most use over the 60+ years. It might be time to pop an ad in the swap meet section They are also available new,but I can't vouch for the quality. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
