2 members (ronsway, 1 invisible), 115 guests, and 4 robots.
Topics128,172
Posts1,057,035
Members48,458
While inspecting my rear brakes I noticed that the brake bar that controls the emergency brakes was missing. :confused: Will any brake bar for a GM / Chevy 15" axle fit? I have a 55 Chevy PU 3100 2nd series.
If not. frown Does anyone know where I could get a set? grin
It's called an equalizer bar, I would think one from a later truck with 11" brakes should work. you may have to make a trip to the savage yard if you can't find one from a parts store.
Bill Burmeister
You can go to NAPA and have them open up their brake book (balkamp???) There are pictures of all the different parts with dimesions and parts numbers. Take the bar from the otherside and find one that matches from the catelog. Shouldn't be a big deal.
V
V Offline
http://www.americanclassic.com has them. Look in the brake hardware and cables listing.
1959 3200 Apache Fleetside
In the Legacy Gallery
