| | | Forums66 Topics128,151 Posts1,056,989 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#60819 05/23/2006 6:19 PM | Joined: Mar 2005 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 28 | While inspecting my rear brakes I noticed that the brake bar that controls the emergency brakes was missing. :confused: Will any brake bar for a GM / Chevy 15" axle fit? I have a 55 Chevy PU 3100 2nd series. If not.  Does anyone know where I could get a set? Thanks | | |
#60820 05/25/2006 8:47 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | It's called an equalizer bar, I would think one from a later truck with 11" brakes should work. you may have to make a trip to the savage yard if you can't find one from a parts store.
Bill Burmeister | | |
#60821 05/25/2006 9:14 PM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | You can go to NAPA and have them open up their brake book (balkamp???) There are pictures of all the different parts with dimesions and parts numbers. Take the bar from the otherside and find one that matches from the catelog. Shouldn't be a big deal.
#60822 05/25/2006 11:07 PM | Joined: Oct 2002 Posts: 96 'Bolter | | 'Bolter Joined: Oct 2002 Posts: 96 | http://www.americanclassic.com has them. Look in the brake hardware and cables listing. | | |
