Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (jay d, 2 invisible), 54 guests, and 3 robots.
Topics128,009
Posts1,055,292
Members48,419
#608197 01/08/2010 3:57 PM
The driver's side window on my '49 1/2-ton stays up while the truck is standing still, but works its way down while driving. Is replacing the spring in the window regulator a weekend project? I've also noticed that the window is not square to the frame. One edge of the window reaches the top before the other when rolling the window up. The regulator has elongated holes where it is mounted to the door, but no matter how I install the regulator, the window does not track squarely in the window frame. This doesn't seem right.
norcal49er #608204 01/08/2010 4:19 PM
Probably finding a replacement spring will be the project. I suggest checking the swap meet or placing a want ad for another regulator. Also the vendors (see the home page) will likely have reproduction ones.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
It sounds like you have more than one problem going on. I would think that you would want to replace the track at the same time you repair the regulator. If it were me I would try and get another assembly.
1951 1 Ton Completed
truckernix #608299 01/08/2010 10:24 PM
norcal...As the other guys have said,it might be an idea to try and locate a replacement.
It sounds like things are very worn, the drivers regulator would more than likely get the most use over the 60+ years.
It might be time to pop an ad in the swap meet section
They are also available new,but I can't vouch for the quality.
More pix on Flickr.
