2 members (Gray_Ghost, Chip O), 62 guests, and 3 robots.
Topics128,129
Posts1,056,695
Members48,452
I will be putting a small block V8 in my 52 1/2T panel soon. Is it possible, or is there a regular exhaust manifold that I can use and not HAVE to move the steering box. The previous owner rebuilt the front axle ect including new drums/brakes and I would like to leave the steering as is. From reading I see a 19?? Toyota truck gear box is best but is there a "rear exit" manifold or some other one that will work with existing steering box? I have ran across a nice (if there is one) 305 engine with 14,000 miles on it that I will be using. Any help will be appreciated gang or just tell me it can't be done??!! Thanks
Early (55-56) log style manifolds might be what your looking for. The ports may be a bit small for late model V8 heads however.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Does it have the 305 log manifold that drops between 5 and 7? I have seen those work on a couple of occasions, but I think it is try and see rather than a sure fit.
It did not come with the manifolds. I was thinking along the lines of moneypit about using one off an earlier model like the small ones off a 265 or 283 or perhaps one that has the outlet at the back. I just thought perhaps someone else had done it and would save me some time. I don't mind the leg work but all "short cuts" appreciated. Should I come up with something I will surely let the Stovebolt know it. It will be a little time before I get there but I will do it!!! Thanks 4.384toy for your input. I can probably run across a 305 fairly easy. An old friend of mine has an old junk yard type garage and probably has some of each. Thanks guys.
