3 members (Jon G, Guitplayer, Wally / Montana), 123 guests, and 4 robots.
Topics128,109
Posts1,056,269
Members48,439
I'm getting ready to put in a 454 BB into my 1958 GMC Suburban Carryall. I assume that I'll have to box the frame rails, but I'm confused as to the motor mounts. I called Chassis Engineering and others, and they have plenty of kits for 55-57, but nothing for a '58. Anybody done this? How?
Thanks, Mark
Never accept a drink from a urologist!
3B Offline
Hy badmoonreizen, as far as the factory mounts for the small block V8 is concerned they are the same from 55B-59, so I don't see why the mounts you mentioned wouldn't work. The cars however had a major chassis change in 58 which would not require special mounts to install the big block. As to the truck, there may be firewall clearance problems, hope that helps.
3B's got it, on the truck, the frames/mounts will be the same 55-59, the 5-7 mounts will work - buddy of mine has a built 427 in a TF - tight, but no major change required - he didn't box the frame, but should have - thing lifts the front wheels at less than full power eek
Thanks so much for the quick responses. I appreciate the collective wisdom and experience.
