1 members (Hotrod Lincoln),
69
Mod | | | Forums66 Topics128,135 Posts1,056,423 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#60786 05/23/2006 1:51 PM | Joined: Apr 2006 Posts: 136 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 136 | I'm getting ready to put in a 454 BB into my 1958 GMC Suburban Carryall. I assume that I'll have to box the frame rails, but I'm confused as to the motor mounts. I called Chassis Engineering and others, and they have plenty of kits for 55-57, but nothing for a '58. Anybody done this? How?
Thanks, Mark | | |
#60787 05/23/2006 3:47 PM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy badmoonreizen, as far as the factory mounts for the small block V8 is concerned they are the same from 55B-59, so I don't see why the mounts you mentioned wouldn't work. The cars however had a major chassis change in 58 which would not require special mounts to install the big block. As to the truck, there may be firewall clearance problems, hope that helps. | | |
#60788 05/23/2006 4:18 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | 3B's got it, on the truck, the frames/mounts will be the same 55-59, the 5-7 mounts will work - buddy of mine has a built 427 in a TF - tight, but no major change required - he didn't box the frame, but should have - thing lifts the front wheels at less than full power Bill | | |
#60789 05/24/2006 9:40 PM | Joined: Apr 2006 Posts: 136 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 136 | Thanks so much for the quick responses. I appreciate the collective wisdom and experience. | | |
