3 members (WarEagle1, Jon G, Gray_Ghost), 98 guests, and 2 robots.
Topics128,102
Posts1,056,184
Members48,436
1 Offline
I have a '33 1 1/2 ton truck and i need help. I disconnected the bolts holding the front/center propeller covers and that's about as far as i got. How do you split the driveline. I need these off so i can inspect the clutch/pressure plate. For pics see my album. There are 20 something pics.
Any help will be greatly appreciated.
Jeremy
http://s925.photobucket.com/home/jeremy5756/allalbums
The only dumb question... is the question you didn't ask...- Unknown
I can't speak to the 33 from experience but if you have slid the cover back from the tranny...and taken the 4 bolts loose/out, the "yoke" should slide back far enough to be out of the way....I think. Someone with first hand knowledge should be along shortly but maybe this will get you going in the right direction.
It may require a small pry bar to "break it loose" and slid back or maybe a long handle screwdriver.
Keep us posted on your progress.
1 Offline
I slid the center cover back and can see the universal joint. But, i can't see how it seperates. As for the front shaft i can't even see the joint with the cover slid back. See pics in album. This is as far as i got.
Jeremy
Use some coarse emery cloth, and polish the outside of the torque tube. The ball assembly should slide back further, exposing more of the universal joint. I believe the rear end will have to be unbolted and rolled back to get the driveshaft out of the u-joint spline.
1 Offline
WOW!! This going to be a job. Now, i did read an 1 1/2 ton manuel that says to drive a pin out and the UJ will seperate. I don't see the pin.
... Ok, I'm not the expert here and just trying to help you work this out.... on some of the bigger trucks were they not 2 pieces?
Also, when you slid the collar back you may not "see" the bolts holding the driveline to the back of the tranny but maybe its because the "locks" oare bent over the nuts and you can't see them??? Once you get the bolts loose their are usually little "cups" that pull back out of the tranny tail shaft...that is on the pickups.
And, as Hotrod Lincoln said, I have also read sometime/somewhere that it may be necessary to unbolt the rear housing and pull it back?
Hope all this helps lead you in the right direction.
1 Offline
Thanks Achipmunk, I'll try unbolting the rearend and slide it back.
I appreciate all you guys' help.
Jeremy
I havent checked your pictures yet but I will. I just pulled the tranny twice in my 32 half ton and it was pretty simple. like someone suggested, I cleaned the torque tube housing really well behind the collar. then took four bolts out of that weird looking ujoint. was a little tricky getting to them but once they were out, the yoke slice far enough back on the shaft to allow the tranny to lift out. the first time, I didnt know this and I undid all the spring U-bolts and all.. and slid the whole axle housing back.. totally unnecessary if you are just removing the tranny
I was confused, the album said 1 half ton. I didnt at first catch that meant(ton and a half) appears to be different than my little pickup. sorry.
If you can get the rear bell slid back far enough to unbolt the u-joint from the intermediate shaft, it might not be necessary to drop the rear axle. Once that's done, the torque tube and driveshaft assembly can probably be unbolted from the crossmember. The "pin" you're refering to might be through the rear shaft, securing it to the universal joint yoke. I'm not sure it's there, but look closely for it once the bell slides back far enough to expose the u-joint fully.
1 Offline
Hotrod/wenatcheeman, The thing with my driveline it's all clean so, i can see where the shaft slides (stops). This weekend i'll do a once over and prob slide the rearend back.
Jeremy
