1 members (baldeagle),
73
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,037 Posts1,055,467 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 43 | i would like to change my dist out for a later model so i could do away with points. my engine is a 65 gc 230 6 cly. where might i find what i need and what all is involved in installing. is the 230 different than the 235? thanks alot. rar | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The 230 is a whole new animal from the 235 that was dropped in 1962.The best ign for it is the HEI that came on the 78 models up into the 80's. The 75-77 will work good too, but the coil is separate from the cap. One from a 250 or292 will fit. Go into it & make sure the mechanical & vacuum advance are working good. Run a 12 gauge wire from the bat connector to the pink wire on the back of the ign. switch. Install it in the normal way to install a dist. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2009 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 43 | thanks. i appreciate the info. rar | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Id be all over that unit from Langdon's stovebolt, you get the complete distributor and coil for just under $100 and an expert like Landgon to hold your hand, what a deal. | | | | | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | Langdons unit works well
| | | | | Joined: Oct 2009 Posts: 19 New Guy | | New Guy Joined: Oct 2009 Posts: 19 | Thanks for posting this. I ordered mine today! | | | | | Joined: Dec 2009 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 43 | thanks, know what to get now. love this forum. really helps out. rar | | |
