0 members (),
139
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 8 New Guy | | New Guy Joined: Apr 2008 Posts: 8 | I'am pulling the 228 out of my '49 GMC FC102 what are the best lifting points for this monster? Rear manifold bolt and a water pump bolt? Front and rear head bolts? Then once out, were is the best place to bolt it to the engine stand? Bell housing? the front end is all off, radiator and everything out of the way. everything is disconected and I am ready to put the hoist to it but I am questioning my choice in lifting points. Any advice would be greatly appreciated. 1949 GMC FC102 4 speed 1970 Corvette t-top 350 350hp 4 speed 1997 Chevy Suburban 1500 4x4 1999 Saturn SC1 Bolter#17856
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I take the valve cover off and use the studs that hold the cover on. Make sure you use a spreader bar so you don't bend the studs. If you're going to dissemble the engine anyway, pull the rocker shaft and use a couple of the rocker bolt holes. I would be afraid to put an engine on a stand with a bell housing. It is cast and can break. Once you have the engine hanging, remove the clutch, flywheel and bell housing. Bolt the engine to your stand using the bolt holes that held your bell housing. Unless you have a really heavy engine stand, you might consider supporting the front of the engine with something. I have a heavy stand, but I have a leg that I bolt to the engine for more support while I am honing or torquing head bolts or main bearings. | | | | | Joined: Apr 2008 Posts: 8 New Guy | | New Guy Joined: Apr 2008 Posts: 8 | 1949 GMC FC102 4 speed 1970 Corvette t-top 350 350hp 4 speed 1997 Chevy Suburban 1500 4x4 1999 Saturn SC1 Bolter#17856
