0 members (), 140 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
#606632 01/03/2010 4:23 AM
I'am pulling the 228 out of my '49 GMC FC102
what are the best lifting points for this monster?
Rear manifold bolt and a water pump bolt?
Front and rear head bolts?
Then once out, were is the best place to bolt it to the engine stand?
Bell housing?
the front end is all off, radiator and everything out of the way.
everything is disconected and I am ready to put the hoist to it but I am questioning my choice in lifting points.
Any advice would be greatly appreciated.
1949 GMC FC102 4 speed
1970 Corvette t-top 350 350hp 4 speed
1997 Chevy Suburban 1500 4x4
1999 Saturn SC1
Bolter#17856
I take the valve cover off and use the studs that hold the cover on. Make sure you use a spreader bar so you don't bend the studs. If you're going to dissemble the engine anyway, pull the rocker shaft and use a couple of the rocker bolt holes. I would be afraid to put an engine on a stand with a bell housing. It is cast and can break. Once you have the engine hanging, remove the clutch, flywheel and bell housing. Bolt the engine to your stand using the bolt holes that held your bell housing. Unless you have a really heavy engine stand, you might consider supporting the front of the engine with something. I have a heavy stand, but I have a leg that I bolt to the engine for more support while I am honing or torquing head bolts or main bearings.
Thanks crenwelge
1999 Saturn SC1
Bolter#17856
