8 members (68ironhead, lumbersawyer, 48jim1ton, Woodcmiami, 3B, J Lucas, Ponchogl, 1 invisible), 97 guests, and 0 robots.
Topics128,049
Posts1,055,553
Members48,425
#606384 01/02/2010 4:29 AM
I have a 1950 3100 with a 54' 235 engine.Does the harmonic balancer suppose to have a bolt in the center of it?I do see something that either looks like a broken bolt or pin?In front of it I do not see any threads?
No bolt on the early 6 in the balancer. Or at least not from the factory. Some guys will drill and tap the crank to take one, though. Otherwise, it's just a press fit.
Bill Burmeister
Thanks Bill!My belt is not aligned it looks like the harmonic balancer has pulled away a little bit.Should I take it off and make it more snug on the crank?I tried to take a rubber hammer to it to make it slide on more but it didnot budge.
Also the noise I get sounds like some kind of grinding!It only happens at idle and not during acceleration I checked the water pump bearings and the generator bearings and they seem fine.Would the harmonic balancer cause a grinding sound at idle if it is pulled away from the crank a little?
Rubber hammer is not going to cut it, not enough force to slide Harmonic Balancer on Crank. I just put mine back on this afternoon using an 8 inch block of 2x4 and a sledge hammer and it slid right on. Just make sure you place that 2x4 on the Harmonic, don't want to risk tweaking it. Good luck
