4 members (MickeyP, Jon G, KCMongo, Gdads51), 72 guests, and 0 robots.
Topics128,051
Posts1,055,705
#60595 05/18/2006 2:12 AM
Junior Member
Junior Member
OK.. I been reading many of the old posts on the baord... so I know this has been beat to death.
I am gonna be putting in a new 4-link rear end soon. Gonna have to figure out the correct angle to mount up the stuff for the spring buckets, shock mounts, etc.
I got the chassis back and plan on mounting the new Mustang II IFS first... then drop in the motor/tranny to get some idea of where motor mounts need to go.
Next I want to mount the 4-link suspension. Needless to say I have to know where all the parts need to be welded on the rear end (with correct angles)
Here's where I have a question... I've been told by SEVERAL knowledgeable folks I need to set the 'stance' of the truck first... (makes sense to me)??
Anyway,.. if thats the case,.. I'm just putting the rear end on a plain chassis. WHAT is gonna happen to the angle when I place the body, bed, etc on the chassis and it gets near completion. Won't the angle change (up or down)??.. and whats the effect.??
Chris
Let's BUILD Something :-)
#60596 05/18/2006 2:41 AM
I would level the frame on jackstands and place your engine. Level the carb flange next by tilting your engine in the frame and maybe add a degree or two to compensate for a rake. Now you know your pinion angle. It's the same as the angle of your trans tailshaft,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#60597 05/18/2006 5:14 AM
With a parallel four bar setup, the pinion angle shouldn't change with load as it does with a leaf spring.
#60598 05/18/2006 9:47 AM
Typically, four bars are adjustable. Get it close then adjust later.
