| | | Forums66 Topics128,052 Posts1,055,725 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#60595 05/18/2006 2:12 AM | Joined: Dec 2005 Posts: 10 Junior Member | | Junior Member Joined: Dec 2005 Posts: 10 | OK.. I been reading many of the old posts on the baord... so I know this has been beat to death. I am gonna be putting in a new 4-link rear end soon. Gonna have to figure out the correct angle to mount up the stuff for the spring buckets, shock mounts, etc.
I got the chassis back and plan on mounting the new Mustang II IFS first... then drop in the motor/tranny to get some idea of where motor mounts need to go. Next I want to mount the 4-link suspension. Needless to say I have to know where all the parts need to be welded on the rear end (with correct angles)
Here's where I have a question... I've been told by SEVERAL knowledgeable folks I need to set the 'stance' of the truck first... (makes sense to me)?? Anyway,.. if thats the case,.. I'm just putting the rear end on a plain chassis. WHAT is gonna happen to the angle when I place the body, bed, etc on the chassis and it gets near completion. Won't the angle change (up or down)??.. and whats the effect.??
Chris Let's BUILD Something :-)
#60596 05/18/2006 2:41 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I would level the frame on jackstands and place your engine. Level the carb flange next by tilting your engine in the frame and maybe add a degree or two to compensate for a rake. Now you know your pinion angle. It's the same as the angle of your trans tailshaft, Scott | | |
#60597 05/18/2006 5:14 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | With a parallel four bar setup, the pinion angle shouldn't change with load as it does with a leaf spring. | | |
#60598 05/18/2006 9:47 AM | Joined: Oct 2005 Posts: 4,251 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,251 | Typically, four bars are adjustable. Get it close then adjust later. | | |
