4 members (tesa, baldeagle, pdlightning, walter74), 347 guests, and 3 robots.
Topics128,166
Posts1,057,092
Members48,463
Hey folks,
Brand newbie here. I have a 61 Apache w/235 but it looks like the carb is from a newer model. All it says on it is Rochester Mono Jet by GM. Mine of course is a manual choke but this one looks like it had vaccuum lines (capped) and a solenoid (no wire) to control the choke. I would like to re-build the carb but I am not sure how to determine which carb it is. I can't find any numbers on it, what is the best way for me to proceed?
Thanks for any help!
Perhaps information on the following link will help you identify exactly which year/model you have. Good luck.
http://www.carburetor.ca/carbs/tech/Rochester/Monojet-index.html
1960 GMC 1/2-Ton Pickup Truck
Updates in the DITY Gallery
k10 Offline
mono jets were from later trucks. The original carb would have been a Rochester B model. I believe that you might still be able to purchase a rebuilt "B" from NAPA to this day.
http://www.napaonline.com/Search/Detail.aspx?R=HOL647073_0180191135#
Looks like about 200 bucks
You might find them on eBay for less.
Many people dislike the B due to warpage and thus difficulty in them remaining leak free. Rebuilding your monojet may just be a better way to go. Or you if you intend on adding a split manifold and other mods, maybe a 2 barrel carb might be something to consider. Something like a Rochester 2GC. You will need a different intake or use an adapter to your original intake.
2GC carb (good price and upgraded)
http://cgi.ebay.com/ebaymotors/Roch...ck_Parts_Accessories?hash=item4cecd00710
2 bolt to 4 bolt adapter
http://www.parts123.com/parts123/yb.dll?parta~partsort
Offy 5710 from Charlie Price's Vintage Speed site
Riding in the Passing Lane
The Monojet has a number stamped vrtically on a flat area on the fuel bowl. You can ID the carb from that number & any parts store can get a kit from that number. It probably had a auto choke. You will have a problem getting it to work because the heat coil was in the manifold. The later models had electric chokes.
1972 Chevy c10 Cheyenne Super
Welcome, Pics of trucks are necessary to let us know what up. smile We like to see other projects to see where you are going with it Good luck!
Thanks, Ben
My 1961 Chevy Pickup Truck
In the GalleryMy Webshots Shoebox
Thanks for all of the help folks! I think I am going to get a rebuilt B and take it from there. I don't like all that extra stuff a hangin' off there if I am not using it.
Ok, I'll try to get some pics up over this weekend. She's a little rough looking but she sure is fun, oh... and my truck ain't bad either! smile
I also have a 61 apache and got my carb from Pace about 3 months ago. Got it for about $120: http://paceperformance.com/index.asp?PageAction=VIEWPROD&ProdID=203011
Well... after researching a little more, I think I have found that this is not the original engine. The casting number on the engine is 3921968, which according to this site: http://www.inliners.org/casting/numbers.html
Which makes it either a 230 or a 250 and is from 64-76. How do I tell the difference? Does the Rochester Mono Jet belong to that engine?
Sorry folks, this is all new to me so I do appreciate the help.
If it is truly a 230-250 they had to change the bellhousing, the 235 has a different bolt pattern. The later 6 has the same bolt pattern as the V/8. That is a benefit for you if you ever considered a V/8 upgrade.
You Learn more Listening than Talking
Thanks Spareparts.
It's all starting to come together now. I think it was originally a straight because it has a small brake pad, not the wide one like an automatic would have.
So, I think it must be a new engine and transmission which would also explain the "newer" steering column and steering wheel as well as the newer carburator.
The Monojet came on 68 up 250's. If it matches the engine & manifold I would use it. They are a better carb then the model B when they work right. If the choke doesn't match up or parts are missing you might find one with a manual choke Or a late model with electric choke.
Thanks Wrenchbender, that is the info I was looking for. I will see if I can find one with a manual choke.
