7 members (GMCJammer51, Youngin' Tut 59, Tim Canfield, jmoore, 3B, 2 invisible), 111 guests, and 1 robot.
Topics128,196
Posts1,057,385
Members48,469
Big Bolt Forum Co-moderator
I am bolting the intake and exhaust manifold for the 1955 235 engine together. Do I need to apply any gasket cement to the gasket that goes between them.
1948 Chevy 2-Ton
Apprentice
Apprentice
NO CEMENT. THESE GASKETS ARE DESIGNED TO BE PUT ON DRY. ANY SEALER YOU PUT IN THERE WOULD ONLY BURN AND CAUSE LEAKING PROBLEMS
RICK
H Online: Content
Ditto! Any gasket that's exposed to manifold vacuum or exhaust gas needs to be installed dry. A tiny vacuum leak will draw sealer into the engine, and probably create a permanent leak, and no gasket sealer I've used in the past 50 years is designed to seal exhaust heat.
Double ditto, and besides, you want to keep the two manifolds loose and movable until after they are firmly bolted to the head, then you can tighten the manifold to manifold bolts.
waldo53, thanks for that tip. I certainly would have tried it the other way first. I was looking through the manual, but couldn't find info on installation. In fact I couldn't find any info about the manifolds. I'll take a closer look today. However, anyone have some more tips. Like bolt torque specs, and installation sequence. I would just guess going from the center bolts and working alternate sides out slowly, tightening a little as I go. By the way, this is my first restoration.
1948 Chevy 2-Ton
