| | | Forums66 Topics128,205 Posts1,057,430 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | I am bolting the intake and exhaust manifold for the 1955 235 engine together. Do I need to apply any gasket cement to the gasket that goes between them. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: May 2009 Posts: 34 Apprentice | | Apprentice Joined: May 2009 Posts: 34 | NO CEMENT. THESE GASKETS ARE DESIGNED TO BE PUT ON DRY. ANY SEALER YOU PUT IN THERE WOULD ONLY BURN AND CAUSE LEAKING PROBLEMS
RICK | | | | | Joined: Feb 2004 Posts: 29,888 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,888 | Ditto! Any gasket that's exposed to manifold vacuum or exhaust gas needs to be installed dry. A tiny vacuum leak will draw sealer into the engine, and probably create a permanent leak, and no gasket sealer I've used in the past 50 years is designed to seal exhaust heat. Jerry
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Double ditto, and besides, you want to keep the two manifolds loose and movable until after they are firmly bolted to the head, then you can tighten the manifold to manifold bolts. | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | waldo53, thanks for that tip. I certainly would have tried it the other way first. I was looking through the manual, but couldn't find info on installation. In fact I couldn't find any info about the manifolds. I'll take a closer look today. However, anyone have some more tips. Like bolt torque specs, and installation sequence. I would just guess going from the center bolts and working alternate sides out slowly, tightening a little as I go. By the way, this is my first restoration. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | |
