7 members (kades51, Southerntruck, Gray_Ghost, Bill Hanlon, Otto Skorzeny, JW51, MRMEROTH11),
82
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,133 Posts1,056,396 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 65 New Guy | | New Guy Joined: Nov 2009 Posts: 65 | Hi, I read that a 292 crank could be put into a 235 block and was wondering what other parts from a 292 motor could be used ?
New but in an Old Way !!!
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | Not true. 292 rods can be fit to a 235 or 261 crank to increase (or decrease) the stroke slightly by eccentric regrinding to the smaller 292 journal size (2.100" vs. 2.311"), but it's a lot of expensive and delicate work. The distributor can be slightly modified to fit, the carburetor is a bit bigger, nothing else. | | | | | Joined: Nov 2009 Posts: 65 New Guy | | New Guy Joined: Nov 2009 Posts: 65 | in reading other topics it seems a 261 is a better candidate than the 235 for stroking with a 292 donor.
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | you really need to research more. you can not use 194-292 parts on a 235/261 other than the rods with a custom ground crank.
The two engines are similar only in the fact that they are made by GM. everything from bore spacing to number of bearing journals, etc. are different. If you have a 292, use the 292.
| | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | the 235 has 4 main bearings, the 292 has 7. The crank will not fit no matter what you do. | | |
