| | | Forums66 Topics128,196 Posts1,057,385 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | A buddy has an original 1936 truck with the four cylinder. No oil filter. He was told he can use synthetic oil in the engine and I wonder. He only drives it about 1500 miles a year and plans on changing it every 1000 miles. Any comments? | | | | | Joined: Feb 2004 Posts: 29,885 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,885 | The burning question would be "Why?" The main advantage to synthetic oil is its extended change interval in new, tight-clearanced engines. That one will contaminate the oil with blowby and corrosive combustion gases in a very short time, so frequent changes would be very much in order. Also, I doubt if synthetic oil in a heavy enough weight to work properly in a wide-clearance engine like that one even exists. I would think a straight 30 weight oil would be indicated, and I've never seen a synthetic in that configuration. Jerry
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | It's driven 1,500 miles a year and he changes the oil every 1,000 miles? Why bother with synthetic oil?
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Agreed, no need for synthetic in this situation. Quick note, Royal Purple does make a straight 30 synthetic, as does Amsoil. Amsoils 30 wt is listed with their Deisel spec oils.
Bill Burmeister | | | | | Joined: Aug 2005 Posts: 94 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 94 | One of our local farm supply stores carries 30W SL rated oil and that is what I use in all my old stuff. I don't think I would even consider synthetic in older motors.
Joe D. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I don't think running synthetic would be a bad thing, but for as little use as the truck will see, I don't think I would consider using synthetic oil either. | | | | | Joined: Nov 2004 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 121 | It wouldn't hurt anything, but if he is going to change that often it will cost him quite a bit more money. Of course, it is his money but I wouldn't do it. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | A buddy has an original 1936 truck with the four cylinder. wait a minuit, what kind f truck are we talking about here anyways???
