0 members (), 151 guests, and 2 robots.
Topics128,195
Posts1,057,374
Members48,469
A buddy has an original 1936 truck with the four cylinder. No oil filter. He was told he can use synthetic oil in the engine and I wonder. He only drives it about 1500 miles a year and plans on changing it every 1000 miles. Any comments?
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
The burning question would be "Why?" The main advantage to synthetic oil is its extended change interval in new, tight-clearanced engines. That one will contaminate the oil with blowby and corrosive combustion gases in a very short time, so frequent changes would be very much in order. Also, I doubt if synthetic oil in a heavy enough weight to work properly in a wide-clearance engine like that one even exists. I would think a straight 30 weight oil would be indicated, and I've never seen a synthetic in that configuration.
It's driven 1,500 miles a year and he changes the oil every 1,000 miles? Why bother with synthetic oil?
Agreed, no need for synthetic in this situation.
Quick note, Royal Purple does make a straight 30 synthetic, as does Amsoil. Amsoils 30 wt is listed with their Deisel spec oils.
Bill Burmeister
1 Offline
One of our local farm supply stores carries 30W SL rated oil and that is what I use in all my old stuff. I don't think I would even consider synthetic in older motors.
Joe D.
I don't think running synthetic would be a bad thing, but for as little use as the truck will see, I don't think I would consider using synthetic oil either.
It wouldn't hurt anything, but if he is going to change that often it will cost him quite a bit more money. Of course, it is his money but I wouldn't do it.
wait a minuit, what kind f truck are we talking about here anyways???
Bill Burmeister
