0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 22 New Guy | | New Guy Joined: Dec 2009 Posts: 22 | I have 1948 3/4 ton with a '56 235. A Clifford intake with 4 barrel adapter and a Holly 390. Just going thru break-in, and find the new setup to be running rich. Can anyone provide a jetting baseline for this carb on a 235? Thanks | | | | | Joined: Jan 2008 Posts: 239 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 239 | How rich is it? Puffing black smoke out the exhaust? Spitting fuel out the tailpipes? Or dark plugs? Rich at what rpm? Stinky at idle? All fixable, but more info is needed. You're probably not even into your main circuits until 2500-3000 rpm, meaning a jet change is not going to affect anything below this.
Devin
If you can't hose it out it ain't a truck
55 3100 63 Corvair Monza 64 El Camino 72 240Z 01 Suburban
| | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Did you get the carb new? If so, they come with a really good CD that takes you through the tuning. Make sure that the choke is fully off, too.
Just my 2 cents.
best wishes,
Les | | | | | Joined: Dec 2009 Posts: 22 New Guy | | New Guy Joined: Dec 2009 Posts: 22 | I don't have much experience with this carb. I have been working primarily with Weber carbs for the last several years, It is a rebuilt carb with no tuning guide. It idles nicely and was running rich at higher rpms during the cam break in. Blackened plugs, rich burn smell, no smoke. There is no exhaust other than the Fenton manifolds. Thanks | | | | | Joined: Jan 2008 Posts: 239 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 239 | First off, get some exhaust on there. Those fumes can kill you. Having said that. there's nothing like the sound of open headers. I don't like them on break in since you can't hear something before it becomes too late.
In any case, it does sound as though it is jetted too big. I'm assuming you've set the mixture screws to highest idle speed or highest vacuum reading, either will work.
Is the truck driveable? I would suggest jetting down 4-5 sizes and going for a 20 mile drive. Should clear the plugs and give you an indication of how total air/fuel ratios are doing. If it starts stuttering and stumbling immediatly, go home since it's probably too lean.
Holley makes a nice assortment of jets from 60 or so to 99, ive used it quite a bit over the years to tune cars in.
Devin
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Yes, As 55Tractor states you need an exhaust on the vehicle to tune. The back pressure from an exhaust will effect the how your carb is tuned. Tune it the way you are going to run it (in relation to your exhaust) otherwise you are wasting time.
Yes, blowing black smoke is running too rich. Black sooty plugs is running too rich. If you are running rich on an open header, I would assume that it will be rich when you get an exhaust on it too. | | | | | Joined: Apr 2000 Posts: 179 Shop Shark | | Shop Shark Joined: Apr 2000 Posts: 179 | I've never used one, but this sure looks like it would be a slick way to dial in the mixture.... http://www.summitracing.com/parts/PHP-15001/
Joe McNeel
http://mcneelnet.com/~jmcneel/59.html
| | | | | Joined: Jan 2008 Posts: 239 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 239 | Might check here for your list number and original jetting. http://www.mortec.com/carbs.htmThe original jetting should be relatively close, as the air and fuel need to be in the appropriate ratio regardless of what engine it is mounted on. There is also a tuning section as well. Devin
